Hi all i am a newbie!!!!
I recently brought my second mini 03 model. Last night driving home the clutch went! only done 33k! The pedal got stuck down i pulled it back up! But now the clutch pedal has no resitance! So feels almost the cable had gone but it did smell a bit. So i dont know really? How much is that going to likely to set me back?
Does anyone know the part no for a mini cooper 2003 model?
Thanks in advance!
Chris
Most likely is the master or slave cylinder has failed and by the fact you say the pedal stayed down my vote is with a slave cylinder (pedal end). Check your clutch fluid level and have a look at each cylinder (if you can see it) and if the area is wet, the seals have gone...
Cheapest place for replacement bits will most likely be brakesint.com
David
