Hi,
Mini cooper S Countryman 4ll 1,6 gasoline engine and year 2010 sometimes go through almost all alarms and can stop power steering and put engine on low power mode while driving. Car has been at workshop few times but they have not found the issue (probably not faced that during maintenance).
Have any of you seen the same issue and found the reason?
Works shop has
Also there is alarms of
So, there has been lot of electrical issues and the car has been multiple times on few different work shop and all the time there is again some electrical issues with this car. This is my mothers car and I have loaned it few times.
All feed back is appreciated!
Joonas
Works shop has
- Went trough the connectors
- Changed
- Crankshaft sensor
- Gasoline pressure sensor
- oil pressure sensor
- gas pedal position sensor
- Engine control unit
- cam chain
- P0015 "b" camshaft position - timing over-retarded
- P0141 O2 Sensor Heated circuit
Joonas
