Convertible roof problem
2741 Views 4 Replies 2 Participants Last post by  SKMayersActs2:38
Hi, I just picked up my secondhand Mini 2004 convertible. Wonderful; love it! I noticed a problem with opening the roof; the elderly owner said he just centrally locked and unlocked and it sorted itself. He demo-ed this when it happened and I was there. (So, I saw that the mechanicals and hydraulics for the roof worked; the sunroof section opens and closes fine). The issue is that I dropped the top fully and then it would not close. No clicks, no mechanical noises, no flashing red light on the button.
I discovered that thee was no parcel shelf in place; the switch had been bodged by someone jamming a small metal key in the switch to make it permanently closed. The key had dislodged when I opened the roof. I jammed the key back in and (seemingly) the roof was working again and fully closed up. I headed home and ordered a replacement parcel shelf, which arrived today.
So, I fitted the parcel shelf, dropped the roof and... yes, roof unresponsive again. I tried the usual advice online (checked both parts of the switch were being held closed by the lever and parcel shelf foot; tried locking/unlocking; tried resetting the central locking with the dash toggle switch). Eventually, I gave up and manually closed the roof (released the hydraulic pressure with a counterclockwise full turn of the screw on the unit, then carefully folded it up until in place with a helper to keep it evenly balanced all the way). Then I pressed the close button and it latched itself automatically, so it all seems to be working, apart from wahtever is stopping it closing in the first place.
I separately noted that the boot lamp doesn't light up; even after I have replaced the bulb. All other interior lights are fine so I don't think it's the fuse.
Could a failed boot light sensor (the plunger switch) also make the car think the boot isn't shut and prevent the roof opening?
Can anyone advise what else to check to resolve the roof (and also the boot lamp, if that is all you can help with)? Sunroof functions fine; opening cycle also
So I found my boot lamp wasn't lighting because somehow the plug with the power cable to the boot lamp switch was disconnected. Now I've reconnected it, the boot light works and the roof also seems a bit more responsive.
I had closed my roof manually by turning the hydraulic pump screw counterclockwise 360 degrees and lifting it back. It all seems to be working a bit better but there isn't enough oomph from the hydraulics; do I need to re-tighten that screw again a clockwise full turn?
I didn’t get a response, but will share my own answer in case someone else comes across this whilst looking for help.
You need to fully retighten that release Valve. Once you do, the system works again.
  • Like
Reactions: 1
Just to finish this topic, my convertible roof was still not working. I also had an intermittent dash light and interior light on, indicating a door/boot/bonnet unlatched. It came and went, sometimes when turning left or right or going over a bump or driving uphill.
it turned out the luggage compartment alarm plunger switch was duff. I replaced it and the dash light went off. What I hadn’t understood is that the boot has to be closed to work the convertible roof and the plunger must be sending to the BCM warning in error that the boot was open. Once the switch was replaced (£10 and 30 seconds to do), theroof was fully working again.
I hope that turns out to be useful to someone.
Thanks for this post. I am looking at an 05 cooper s and the owner said the sunroof portion works but top doesn't open fully. I'm considering not even buying the car since I found this forum today and seeing all the top issues. Did your top work trouble free after you did the repairs?
