need to replace or delete dpf filter at same time , also will new oil feed pipe as well, also on block end of oil feed pipe there is a gauze filter common for this to block up and take the turbo out,, so need to remove this gauze from the banjo bolt and leave it out,, also need to remove sump clean it out and replace oil pick strainer from oil pump also common these to clog take out turbo,,, also pull the plastic cover off top of engine and look at the injectors and check all 4 are tight and have no carbon black crud around them,, if do needs new seals and prob take rocker cover off and clean out around them,, reason behind this is that crud is rock hard and blocks up oil pick u[p in sump and that gauze filter and do what its done,,,
best bet turbo is find a genuine garret one for sale,,, heads up if you just replace the turbo and dont do the rest within a few miles will be buying another turbo for it is the norm,
