I’ve got a Cooper D 2208 that I’ve had a few issues with and working through them. I’ve removed dpf and blanked off egr. I did have issue with fuel additive fault but that is now sorted. No codes except egr after few mins but car has no power. Builds up steady to 3k then stops. Checked hoses all ok. The rod on turbo moves slightly on tickover changing engine note. Could it be the boost solenoid, can it be tested or is it just replace.
