driven under the exact same (normal, 3000 - 4500 RPM shifts...ect.) conditions, and of course un modded, which engine should get a longer life without failure or in need of a serious and expensive overhaul. the cooper or the MCS engine.......
Apart from the supercharger and a few other odds and sods, both engines are identical, so providing all services and inspections are carried out with manufacturer agreed limits and spec's , there should be no different.flav said:driven under the exact same (normal, 3000 - 4500 RPM shifts...ect.) conditions, and of course un modded, which engine should get a longer life without failure or in need of a serious and expensive overhaul. the cooper or the MCS engine.......
I see what you mean, I'd not keep a car that long so would'nt be worried, 50'ks top mileage than move on for meflav said:reason i ask it becuase the S version has some forged internals, but i also heard that the supercharger would need to be replaced around 100,000 and cost a couple 1,000 $$$$.
