Cooper S R56 N14 spark plugs
6787 Views 14 Replies 4 Participants Last post by  mike1967
Quite simply what spark plugs goes in a stock Cooper S N14 engine?
Thread below suggests PLZBR7A-G but I can't find such a model only PLZKBR7A-G
A basic guide to Spark Plugs.
Just need something that works, nothing fancy.
1 - 15 of 15 Posts
It's probably been superseded by another, try NGK web site & cross reference.
  • Like
Reactions: 1
This is what I run but not currently. Right now I am running NGK R.
Metal Cosmetics Lipstick Brass Ammunition
Writing implement Stationery Ammunition Office supplies Metal
Metal Brass Stationery Silver Bullet
The first is
1.)NGK IR ILZKBR7A8G JAPAN
2.) IRIDIUM by BRISK PREMIUM+ P8
3.) BOSCH IRIDIUM R6 ZR7S1332S GERMANY
  • Like
Reactions: 1
IRIDIUM plugs on standard n14 coil packs not the best choice as coils are weak and plugs are hard,, ok on later n18 engines as coils were upgraded,, better off with plats in them
  • Like
Reactions: 1
cheers guys I will do a search on ngk site
I would gap those tighter then recommended as I have a turbo engine. Also not to use spark plug die electric grease in the coils as it can make them fail. finally I would not use anything to put on the threads of the spark plugs to make it easier to remove from the cylinder head when they get old. Sense it is aluminum.
  • Like
Reactions: 1
we found that on turbo cars at top end revs when mapping them on rolling road we found 0.18mm to be what worked on the cars we done over the years,, coils packs are weak then get older adds to it
Mike what did you mean by they are hard?
iridium plugs are harder plugs designed for very high temps and big power where the combustions processes are very high but harder the metal the more dense it is this causes a high resistance for the electric protons and ions makes it harder for them to travel through a higher resistance metal like iridium,, on n18 they have increased the output to produce a heavy spark,, the plats is less resistance and allows them to travel with what can be produced from the coil pack,, a coil pack is a capacitor has windings and non conductor screens in side as such,, so 12v charges this via main ecu the capacitor saves this and amplifies its 10amp 12volts to maybe 240.000 volts at 00.10volt ie low volts high amps this gives a lightening effect ie the spark,, as its tiny volts its hard fro the coils to power through high resistance ,, the switching on this circuit is ecu earth switched so the ecu cuts and engages the earth circuit only as control this prevents spikes back to ecu and better control,,,
so car makers would of spent millions on this design around the plugs and engine to get it to run in a way that will last,, if wrong plugs can cause pinking or knock where the system is designed to give a timed spark allowing for slight delay in the journey from ecu to tip of plug,, increase the resistance reduces the spark and delays it slightly,, might not notice this at low revs as much but when bouncing off the top end where a spark is happening will ,, i found when used iridium's in the past i got more back fires on over runs,, the guy i use for repairing high pressure fuel pumps explained this to me a few years ago and it does make sensor,, hence why you can now buy stronger coil packs for n14 cars and the cars with 300bhp and forged use them and with the iridium plugs as on those cars work really well ie less risk of melting the tips of them when running big power .
below link best coil packs
  • Like
Reactions: 1
Thanks Mike, that makes a lot of sense, thanks for all that write up.
My coil packs been replaced by BMW 6 months ago and I see no point replacing them at this point so I'll go with platinum plugs as mine will be a very boring street car.
plats are good plugs think people read stuff on internet but dont read it all, ie get someone who has melted the tips off a plat plug but dont tell you that he's also had a lean out and that was why and nothing to do with the plug,, on a forged with bigger boost and fuel to add then they go with hard plugs and better coils,, no brainer on that ;level, i got a n14 booked in for next month that is having it all done and will have those coils and indiums forged and better turbo as well bored out max etc, also golf a monster to do as well vw golf r32 pull engine forge it and chain kit bored as well and some head porting and valve work etc, then its having a twin scroll turbo fitted from a kit £1400 for the kit aiming at 600bhp might even go down road of a super charger as well,, that v6 3.2 engine is so strong for the off and most people run a mile form them as so expensive for parts ,, just one camshaft adjuster ie vanos sprocket is £560 it has two, even head set is £350 just a money pit really but keeps me busy lol
  • Like
Reactions: 1
I wonder if you could share rebuild details with pictures on the R32 if you can Mike on a separate thread, I'd be really interested on following that.
will do when i get going on it its still in the planning stage also we been thinking maybe a sleeper car and not destroy a rare r32 might be how it turns out as that engine has been put in many vag and Porsche cars and his r32 is so clean and tidy i keep telling him think its wrong for that car until it starts failing as they all do i guess,, i done a engine refresh on a audi 3.2 v6 2004 last year its also puts timing chain at rear of engine so engine and gearbox out to replace it like bmw n47 diesels,, link below for that job it towards the end of that link pages will see the 6 cylinders in one block ie v6 with single wide head
I did come across that thread a while back Mike when I was searching for N14 stuff and it was very interesting to see you use wellseal on stemseals
Not sure if it's right saying it here but Golf is my favourite daily driver car, for me it's reliability and build quality second to none for a street car.
My next daily runner will be a golf mk7 or mk 7.5 , been always fascinated by R32 and VR6, Once I sort this out my R56 and give it to my wife I can look for one of these as my next project.
I was looing at various project cars before I purchased R56, Supra Mk3, MR2 Mk2, Porsche 944, Golf R32 and VR6 are few I was giving a thought.
the vag stuff is all good its getting a bit weaker on newer stuff ie built light to emissions targets, i got Toyota supra twin turbo mark4 i saved from scrap years 2001 its a 94 car uk model 80k on it have it stored for past 15 years lives in a polly bag paid 4k for it back then with rod out side of block, stuck another block and forged it and hybrid etc was banging on 600bhp at wheels ,, put it back to factory all but the internals when seen they were going up in money, found as it got older the parts became more expensive as well,, i've had sports bikes all my life fireblades and gsxr 1000 s as well and that car when running hybrid was only car that came close to how on the edge riding a sports bike is ,, got old now need my licence and rather have the money than the damage etc
1 - 15 of 15 Posts
