Cooper S R56 Still leaking oil...
2218 Views 3 Replies 4 Participants Last post by  mike1967
So ive changed everything including: Oil Filter housing gasket, Vacuum pump, Oil Filter Rubber, Turbo oil feed pipe, Rocker cover gasket.
Im running out of ideas and its still dripping oil from somewhere. Does anyone have an idea of what it could be or are there any common oil leaks apart from what ive listed.
I'd suggest you wash the engine off, let it dry & then give it a liberal dusting of talcum powder.
That should give you some clue.
& smell nice.
rear main seal... might as well buy a flywheel and a clutch while youre at it as well as a pilot bearing
below link a good way add to oil go find the ultra violet colour with ultra violet light save a load of guess work
https://www.ebay.co.uk/itm/UV-Dye-T...3:g:e1MAAOSw44BYWmMp:rk:1:pf:1&frcectupt=true
