Hi All,
I just took my 2007 Cooper S to have 4-wheel alignment check and correction.
The guys tried to adjust the toe on the rear right side but said they couldn't adjust far enough to get it good. However they did adjust the front for me.
Apparently to adjust the rear toe the bolts holding the trailing arm bushing to the body can be loosened. There are elongated slots in the bushing bracket so it can be slid on the bolts. They suggested the trailing arm might be a little bent but were not 100% sure why they couldn't get it adjusted correctly.
Possibly could they be not adjusting right? At first they said the control arms are adjusted, but then said they were wrong and it's the trailing arm as above. Is it the R53 with adjustable control arms?
Has anybody had a similar experience? Comments welcomed!
I can swap the trailing arm (is it difficult?) but would like to know this is the problem first.
