My 2011 Cooper S tries to start and then dies, the scans point to a fuel supply issue , Bimmerlink reports fuel rail pressure on cranking at 17 psi, low pressure at 72 psi but it is constant at that even when there was no starting problem. it also listed a error code of 2C0F with a description of 0x2C0F fuel pump relay, control:short circuit to earth.
Any advice on location and checking of this relay and the other faults would be appreciate.
Mel.
Mel.
