2006 Mini Cooper, manual transmission
Is anyone with a Cooper S 6-speed manual (or if you just have knowledge about it) able to tell me the part number of the transmission support bracket?
I have been doing a 5-6 speed Getrag conversion on my R50 mini. I installed the transmission yesterday and was disappointed to see that the transmission mount doesn’t line up with the support bracket:
282478
None of the conversion threads or documents I’ve seen have mentioned getting a new support bracket. I’ve been looking online for the correct part number but it is not easy to figure it out. Part numbers I’ve turned up are:
22316779909
22116756221
But I don’t know if either are correct. Any help would be much appreciated!
Discussion Starter · #2 ·
Ok, I contacted theminiguy.co.uk who apparently does 5-6 speed conversions and he verified the part number is 2211 6756221. And apparently the 5-speed Midlands uses the same as the 6-speed Getrag but the 5-speed Getrag uses a different one which is why mine isn’t lining up.
