Have you tried rotating the LED bulb adjustment, as most will have adjustment so that you can get the beam correct.
Not sure if you seen this
www.mini2.com
Also worth noting the cheap LED bulbs you can buy from ebay, Amazon, Aliexpress etc... will not give you the best results unless you try countless ones.
Also the type of headlight housing is important to the type of LED bulb you'll need, it isn't straight forward plug n play.
Mini Cooper Clubman - Decent Lights at last - and how to...
After 8 years of our first Mini Cooper we have bought a 2010 Cooper Clubman - which is great, well, apart from the horrible headlights. I fitted the usual Osram Nightbreaker Unlimited Halogens, they were a bit better but still absolutely awful. I've always steered clear of fitting LED lighting...
