2010 JCW coup
Purchased a 2010 jwc about 8 months ago, we installed a frame hitch and we tow it behind our motorhome. I've been visiting this forum for quite a while and finally joined, Few weeks ago it started with the cold start problem of dying and rough idle, after it warmed up it runs great so I have ordered a new fuel pump and also a tensioner, I did the measurement and came up at 66 mm but the tensioner seems warn, when you push it in is very rough and not smooth almost like it's got little Pebbles or something in it. I also pulled the valve cover and everything looks pretty clean so hopefully I still have a few good miles left in it. I will update as soon as I get the parts in and installed and hopefully it will take care of the problems I'm having. Also changing the low pressure fuel filter so hopefully have all the bases covered . All parts are from FCP.
Grey Gas Wood Artifact Concrete
Motor vehicle Font Gas Automotive exterior Auto part
going by the chain guide colour chain will be stretched for sure , adding a new tensioner to worn chain system on gen 2 cars not best idea to be honest , those tensioner are all a tad notchy and normal as spring inside touches the inner slide part ,, the tensioner dont travel much on a engine without stretched chain so spring just holds chain to guides and sprockets,
2010 JCW coup
I was kind of afraid that would be the case LOL I guess I need to bite the bullet and just get it done plan on keeping this for a while it's such a pleasure to tow it behind the motorhome, don't even know it's there and it's fun to drive. I have read a ton of your posts and I am going to take your advice you really seem to know these cars inside and out, really unfortunate that you're not my neighbor haha.
