I own a 2003 Mini Cooper S. When I got to work this morning and shut off the car the dash lights didn't turn off. I checked to make sure the headlights weren't on and anything else I figured might be the cause but still the speedometer and tachometer etc remain lit. I even un-hooked the battery and once re-hooked the lights resumed to be on... Any ideas?
Have you tried turning the headlights on, then off again?
Mine did this once when I switched the lights to Auto without the key in the ignition.
I'm not too sure why or what happened, but turning the lights on then off with the key in seemed to fix it.
Another good one I had was using the radio without the key in the ignition, ment that the MFSW remained illuminated even when the radio was off and the car locked!
I am currently having the same problem with my 2003 mini. Does anyone have the schematic for the instrument lights circuit?
