1 - 18 of 18 Posts
Anyone use a dashcam in their Countryman? I only just noticed today that there is still power going to it after I've locked the doors. Car is plugged in and being charged via a three pin, so not sure if that has an impact.
Cool, thanks Paul
Tempted to get a separate battery pack and hard wire my dash cams in, as I have a rear one as well. Idiots down my street park badly and had the car scratched up badly in a public car park before...Then at least I can run them 24/7
Funny I noticed exactly the same last night. I took it off charge, locked the car and noticed the dashcam was still on and the top edge of the centre console was flashing red every few seconds.
It all turned off after about 5-10 minutes
Discussion Starter #5 (Edited)
Finally had a chance to retrieve the memory card, wanted to heck how footage looked out of the rear camera, as I hadn't used it before. Turns out that the earliest footage was from 1am last night, when the car was stationary. It stayed on for about an hour and mysteriously stopped. It then came on again at 8am this morning, but that could have been part of pre-conditioning...Might need to hardware the cam into something else that properly turns off with the ignition, if I can't figure out to turn the camera off in the settings. I noted that the voltages are slightly different when the ignition isn't on.
Edit....
Plot thickens...this only happens when the car is plugged in to charge...
On my current Leon I have the dash cam wired into the fuse box via an adaptor.
Which fuse is the best to tag onto?
Sorry this is an old post, but I'm curious where you placed the rear camera? I've been told to put it above the number plate and also been told its fine on the parcel shelf if you bend the camera to the correct position.
Also, did you wire it to the reverse light? And if so, would you know which wire is the reverse light? I have a cooper and the light is On the bottom of the bumper, you have to get under the car to access to bulb.. And the wire I have just isn't long enough to be routed under the car
LeeHughes, what do you want to use the camera for? Is it actually a reversing camera, which would only operate whilst reversing the car, or is it a rear view camera for a dash cam system? Depending on it’s use, the connections will be different.
Discussion Starter #9
hmm, come to think of it, I didn't do any research when it came to sticking up the rear dashcam. I've stuck it right at the top of the rear window. It came with a long enough cable to lay along the bottom of the car and then up the front to the front camera. Car is a lease, so can't do anything too complicatd with the wiring, as I'd have to rip it all out and return the car.
A friend of mine also has a camera at the top of the rear window, which did capture a person in a balaclava using a repeater to unlock his car...doh
The plan is to use it as a reversing camera, the device I have actually records the rear view constantly when the rear camera is hooked up but you can't see it in the display unless it's in reverse.
I might try placing it at the top of the rear windscreen for now. It's just the 12v wire I have issues with that tells the screen to switch from the front view to the rear view.
Ive found a few videos on accessing the reverse light but thay requires me to get under the car, i don't have an impact wrench so just incase the only way to do this was to get under the car to access the reverse light I've soaked the bolts in w40 just incase I need to manually use a spanner and elbow grease as I did a quick test and they are seized on pretty tight .
All my sockets got stolen about a 6 months ago because I stupidly kept them in a shed and I just didn't have the money to replace them. I've got some insurance money coming soon so I think I'll buy a cheap set, and then pass them down to my son when my health is bad enough I can't work on cars anymore.
Thnx for the reply mate, I appreciate it
Got my PHEV yesterday, got my Dash Cam wired up this afternoon, having trouble with my phone so have no pics of the installation.
Cable pushed nicely it the gap between the headlining & the screen, also down the A pillar, removed the side panel where the air bag switch is and connected the supply to one of the unused fuse ways. All working fine, comes on with the ignition and switches off when ignition switched off.
I’ll see if I can get a piccy of the fuse box
Did yours come with rear view camera?
Ive got my setup wired up now apart from the rear camera. Chemo has been a ***** the last few weeks so I've not even considered taking the rear clusters out to trace the 12v+ for the reverse light. I never could find the wire to splice for the reverse camera. I was gonna pop out the reverse light in the bumper, then follow the wires to find where it enters back into the car to find a decent splice point.
Sorry no reverse camera, I suspect there is an unused socket behind the number plate for a reverse camera to plug in. I have had no reason to search for it, so have not looked, sorry not to be of help.
When you say unseen, would you go for the type that replaces your rear view mirror? or the clip behind the original rear view mirror?
Yes i would like one that hides behind the rear view mirror,i'm not interested in seeing a screen.I have a Nextbase 402G which sits behind my Lexus RX rear view mirror and you completely forget its there.
I also have a spare one of these cams but it just won't fit right in the countryman.
Discussion Starter #18
This is the final straw, was out at National Trust, Chartwell. When I came back to the car, someone has basically hit and run. A similar thing happened to my previous lease car, but that time in a Sainsbury car park. I'm now looking at getting the Cellink NEO to power the dash cam and provide park mode monitoring. Hopefully I'll catch these silly drivers, if it ever happens again
1 - 18 of 18 Posts
About this Discussion
6 Participants
Shiki2000
MINI Cooper Forum
Full Forum Listing
