1 - 1 of 1 Posts
I thought I'd share these volume control files received from Dension whilst trying to sort my distotorting classic and touch ipods on my new Gateway 300.
2 files, one for v1 firmware and one for v2. If you don't know which you have don't use them.
To use, load one file only onto a USB stick, it should be the only file. Plug it into the USB port whilst the port is on and wait for the light to stop flashing. Remove the USB stick and power off the Dension and then back on again. I used the -6db file which has set the volume to a similar level to Radio 1. I also powered off the Dension by removing its cable.
USE AT YOUR OWN RISK!
1 - 1 of 1 Posts
