Different sized tyres
748 Views 7 Replies 3 Participants Last post by  obehave
I wonder if some of the more technical (read: nerdy :p ) could help me.
My Zafira runs on 195/65/15 tyres and I've been offered a brand new set of Vauxhall alloy wheels and tyres which are 205/50/16 by a friend who has bought a new car but is upgrading to larger wheels.
As I understand it, the correct size if I increase wheel size would be 205/55/16. So would the different size make too much difference to the speedo reading? I could happily live with it if it's not too much of a difference.
507mm v 508mm overall diameter Che, should be a negligible difference..........:)
Thanks Aiden. :D
I've never thought of you as a nerd. :p :D
Not according to this site
Speedo will be off 3.63% at 60MPH.
There's a 2.9 inch difference in circumference.
Your gas mileage will appear worse but the car will be quicker from stop lights and pull a bit harder due to reduced final drive ratio. Cruising rpms will be higher as well.
I thought there may be a difference of up to 5%.
Any safety issues?
:eek: I stand corrected - I did a straight calculation on profile ration versus width of tyre, plus the diameter of the wheel in mm...........I thought that was the correct way? :confused:
dietcokeplease said:
Thanks Aiden. :D
Seems you were right...............:p :D
I'm dependent on the nerdness of others :D
