1 - 1 of 1 Posts
All 4 wheels pointed down
Has anyone else seen this? Appears the website was just updated?!?! Do you not get the same components from the JCW kit as you do with the Stage 1 kit? And JCW is cheaper?
Still waiting for the pulley! :(
Suspension Systems
4/02-2004 Production
Stage 1
Part #:
Price:
D190-5301K
$1096.00
Labor Units: 69.0 Units
List of Included Items: Performance Spring Set; Koni Adjustable Struts and Shocks
Special Notes: Front Camber Plates may be added to the Stage 1 System (Part #D160-0001 @ $199.00).
Dinan's new Stage 1 Suspension System for the MINI Cooper S provides the additional grip and balance that enthusiasts demand. The system features performance springs and matching Koni adjustable struts and shocks, reducing body roll and improving steering response for an even more exciting driving experience. The modestly lower ride height provides improved suspension geometry and a more aggressive stance, while maintaining adequate shock travel for a firm yet well dampened ride.
Front Camber Plates may be installed in conjunction with the Stage 1 Suspension, inducing more negative camber on the front wheels for a dramatic reduction of understeer and crisp turn-in.
Dinan suspension programs are the definitive solution for those seeking outstanding street performance, as well as a very capable MINI for track events and driving schools.
Stage 2 Suspension System
Part #:
Price:
D190-5302K
$1385.00
Labor Units: 84.0 Units
List of Included Items: Performance Spring Set; Koni Adjustable Struts and Shocks; 19mm Adjustable Rear Anti-roll Bar.
Point Value: 5
The Stage 2 Suspension for the MINI Cooper S adds an adjustable 19mm rear anti-roll bar to the springs, struts and shocks included in the Stage 1 system for greater control over body roll as well as improved balance, further reducing understeer. Molded rubber bushings are included for years of maintenance free performance without the squeaks and groans associated with the more typical urethane bushings supplied with aftermarket anti-roll bars. Dinan sweats the details so that you don't have to down the road.
Stage 3 Suspension System
Part #:
Price:
D190-5303K
$1584.00
Labor Units: 94.0 Units
List of Included Items: Performance Spring Set; Koni Adjustable Struts and Shocks; 19mm Adjustable Rear Anti-roll Bar; Front Camber Plates.
Point Value: 5
The Stage 3 Suspension for the MINI Cooper S adds front Camber Plates to the Stage 2 components for a dramatic reduction of understeer and more immediate turn-in. The Camber Plates induce more negative camber on the front wheels by relocating the upper strut mounting point inward. Not only will your MINI Cooper S handle as if it were on rails, but aggressive drivers will also enjoy more even tire wear as more contact is maintained during hard cornering, reducing the accelerated wear on the outside edge of the front tires.
1 - 1 of 1 Posts
