My first cable was a direct 3.5mm jack to header. To do this I found a CD-ROM audio cable and took the plastic ends off the cable. I then superglued them together to make a 2x4 header connector. Make sure if you do this you align it right! ie the sides with the little clippy things are on the outside.
One problem I ran into, was I couldnt get to one of the screws on the side of one of the columns, All the photos I had seen had the pop out knee bolster, however mini had the little cubby hole, and i convinced my self it was screwed in! Eventually after looking up with a torch and realising there were little hinges, I got the courage to try tugging it and it came down like I had see on another thread! Woohoo!
After getting to the back of the radio, i gave my cable a test, diddnt work, not surprising really, but since others have used a capacitor based circuit to get the headunit to reconise the cable, I tried, out of curiousity gripping the jack connector with my thumb and finger, and huzzah, I could get to Aux!
I then put the following circuit into my wire:
I diddnt have a 300k resistor, so I used 3 100k's in series.
And what dyou know, it works!
I had a female 3.5mm jack lying arround, so I decided to mount that. Unfortunatly, I accidentally snapped the plastic tray bit under the console, so I decided to hold it in with 4 tie wraps. Sounds dodegy, but you cant see it and you cant really see the tie wraps either, so its fine!
(in one of the pics tho, you can see my crappy attempt to mend the crack by melting the other side together with my soldering iron! the revealed side looks fine now , phew!)
Anyway, hope you enjoy!
Anyone wanting an aux input on their mini should do this if they are confident enough to do this and are able to make the little circuit. Its much better than fm transmitters, I can tell the difference, especially with the HK. £40 for the proper cable is a joke!
James
