1 - 9 of 9 Posts
Wondered if anyone knows?
I had a pipe burst on my 2006 R53 air con system a couple of years ago. Have finally got round to replacing the pipe, also a new condenser/drier was fitted and has been re gassed. According to the guy who gassed it, it is holding at the correct pressure.
However when i switch the aircon on, the compressor does not come on. It has climate control, the green light stays on solid to say all is good but no cold air and no compressor!
I have just tested the first stage fan which I believe is also supposed to come on when the air con is on, and this does not work. The second stage is fine and comes on at 112 degrees.
Does anyone know specifically if the first stage fan doesn’t come on, will it stop the compressor starting up?
yes its all linked the condenser ie the fan on front of car must have clod air pulled through it to cool the gases so they start the journey gain ie to pump and then to evaporator, when engine is running doe the clutch engage on air con pump can you see it spinning, also get someone to switch air con on in car while watching the pulley, if pulley runs briefly then shuts down on some cars the system senses a fault with cooling fan circuit and will shut down the clutch on the pump.
below link common fan problem, pack lives within the radiator cooling fan plastics behind the rad,
https://www.ebay.co.uk/itm/FOR-MINI...548747?hash=item2ace58be0b:g:FXUAAOSw9YFdB2du
Further to my last post, no, the clutch does not engage and there is no movement from it at all. I have checked the relay and thats ok.
Is it likely that the 1st stage fan not working will prevent the compressor from starting up? Or something else?
i would run a multi meter to compressor wiring plug search for a voltage, if no volts then its further back i would say while fan not work the system will be shut down to protect its self from over heating, if have voltage at plug then its compressor at fault, but i'm pretty sure that system will not run with a faulty fan
added point you really do need to sort that fan to run as per designed anyway as letter engine run to a hotter point all the time when it dont need to puts more stress on it.
Thanks again mike! Will definitely be sorting out the fan ASAP was just hoping to have everything I need to fix the air-con too whilst it’s all in bits!
i think after you fix the fan the aircon will work, more chance than not. there should be two relays in the under bonnet fuse box for both speeds as well off the top of my head
Discussion Starter · #9 ·
Just an update to the fix of my air con. With the bumper and crash bar off and just the top rad hose disconnected there is enough space to pull the rad forward and get to the resistor.
Once this was replaced I had a quick look at the compressor to find that the plug wasn’t properly connected!
So in answer to my original question, I can only surmise that the first stage fan not working was what caused it to overheat and burst a pipe in the first place however due to the plug being disconnected(most likely at the garage where the new pipe and condenser were fitted recently) I can’t be sure that the blown fan resistor actually stopped the system from working!
Fan is now working as it should and aircon too ?
1 - 9 of 9 Posts
