2005 R53, 2005 R53 lightweight, 2008 R55S, 2012 R58 FJCW, 2014 R60SD All4, 1996 Mini Cooper 35SE.
not😂
(13) Mini R58 N14 FJCW with an interesting fault it doesn't know it has ;O) - YouTube
cam timing is good enough
history of this car is it had chains, head strip, clean. seals, valves lapped, pistons out, cleaned, honed, rings, end shells, ARP rod bolts
then it had a major overheat while in use as a courtesy car which appears to be down to the aux coolant pump body splitting on the motorway, this melted the thermostat housing, rocker cover, and partial inlet manifold, adding a 0.014" warp to the head
hey ho, moving on....
new OEM stat housing and updated harness, crossover pipe (again), aftermarket rocker cover, substitute inlet manifold, since replaced with original for testing, and also a used throttle housing due to a spring test fault recurring sporadically, and this time the head has ARP studs added, as it had also been remapped.
before the overheat it drove lovely, and immediately after the head repair it also went like stink, then started hunting and became erratic with some stalling after 15 miles, no stored faults since the original motorway overheat other than the throttle housing which was intermittent and now clear. The oil pump was a bit noisier on rerun and it did bring on the oil pressure light at junctions on initial road test which a switch didn't solve so have just swapped the scored pump and that's no longer a thing.
adaptions have been reset after various bits swapped, just because.
bank 1 lambda also substituted for testing, diverter valve intact and spring good, PCV pipe intact and crankcase vac is good, vac pump vac present, wastegate holds vac and functions as does diverter in active tests.
the downstream lambda says 'not ready' I can see in live data in another clip, also smooth running data isn't populated where it is on a similar non JCW car here but that has other stuff going on, yet both are showing the same as this car on another JCW 'tuning kit' car here which runs great, HPFP actual/target are close, motor has no knock, no misfire count etc.
posting as am curious if people have had a car doing similar?
