1 - 1 of 1 Posts
Going up in the world
Had a problem recently with the passenger door latch on my 2003 cooper. The door would not lock and unable to open from inside. The problem located to the locking mechanism which is basically unserviceable. A new unit was required which I fitted myself after much head scratching. If you have this problem ( I think it's a common problem) it is quite easy to change the unit out. The main problem is getting the latch unit passed the window guide runner and re-connecting the interior door latch cable.
The window guide can be moved easily and the interior door latch cable is connected prior to repositioning into door passed window guide.
Saved me money and took around two hours.
1 - 1 of 1 Posts
