Hi guys!
Just bought a 2011 Mini Countryman All4, as it's bucketing down today when I've got into the car I've noticed that there is water dripping in by the accelerator pedal down onto the carpet.
I've read about drain holes but the only one I can see is the on the passenger side by the windscreen,if this was blocked would it drip into the drivers side? It's quite bad so need to get it sorted asap, I think it's coming in from dripping into the gap from the engine bay onto the drivers side front wheel arch, is this a known problem?
Many Thanks
Mark
remove the wipers and plastics under the gap in between has drain holes in the bottom corners like rubber socks as such
Hi John,
thanks for your reply, do these rubber socks get clogged up? Do I need to clean them etc?
Many thanks
yes they do one is under the brake servo the other is on other side its is a service item ie when service tech should clear them as well as the slots on the bottom of the doors under them as such i use a cable tie to poke them through
