ive gotta lose 25kgs to get rid of this noise?dairyboy said:I've tried everything except pulling the seats apart. My solution to the problem (I suspect..) is losing weight - I am 90kg but when my 60kg brother sits there, the noise isn't there no matter how bumpy the road is.
kapps said:There's a thread around here that says what to do. Basicaly, slide the seat all the way foreward, tilt it all the way up, and then push the release like you were going to get in the back seat. If you lay on the back seat, you can see under the drivers seat and spray some penetrating lubricant on the metal ball joints on either side of the seat bottom. I did it once and it ended 2 years of squeeks![]()
Thanks, I'll have to try that because my dealer has been useless and it is driving me nuts. OK, so that isn't very farkapps said:There's a thread around here that says what to do. Basicaly, slide the seat all the way foreward, tilt it all the way up, and then push the release like you were going to get in the back seat. If you lay on the back seat, you can see under the drivers seat and spray some penetrating lubricant on the metal ball joints on either side of the seat bottom. I did it once and it ended 2 years of squeeks![]()
