Hello everyone ,
I'm a R56 Mini owner for a couple of months, i need to say that mine is not converted from automatic to manual(i've checked from VIN , it is Factory Manual). i want to explain my problems briefly ; firstly mine has issue about steering angle sensor(SZL) ,for instance the signals wont stop itself after turns,when i turn off the engine wiper works automatically ,also when i press the DSC button nothing was changing (no DSC light came on) ,when i activate the CC system its green light appear on the speedometer and it stays there till i deactivate it again ,but it did not work.I thought that all of them were caused by SZL unit.
SZL unit is repaired after these symptoms appear(i did not buy a new SZL unit btw.) and most of them are fixed except DSC and CC probems. Nothing has changed about DSC and cruise control , still nothing happens when i press the DSC button and also its green light turns on when i activate the CC system but nothing more.Today , to get error codes i've connected my car to diagnostic device. i've attached the link of pictures and error codes below .
ECM channel ;
3099 no EGS message,reciever DME,transmitter EGS(current)
i may be wrong ,but EGS fault is related with automatic BMW/Mini cars or the cars that are converted from automatic to manual transmission ?
others are caused by downpipe and water pump and i guess these are not related with my problems but if u want i can translate them into English just let me know.
ABS channel;
5DF3 DSC DME/DDE interface signal fault(current)
5E06 no signal from left rear wheel speed sensor(history)
Some people said that it might caused by ECU or ABS module .
i wish u guys can help me and give some idea about these problems .
Kind regards.
