early non dpf ford focus engine fitted in to a 2008 mini cooper d
1K views 0 replies 1 participant last post by  mike1967
#1 ·
just a heads up to buying a replacement engine for mini cooper d 2006-2010 psa engine, well same 1.6hdi engine is fitted in to the ford range from 2004 to present the early engines were non dpf engines and fair bit different on all the sensors and other stuff, so i have many times fitted Citroen and Peugeot and later dpf ford engines and head to mini cooper d as can buy them a lot cheaper from breakers but always bought same year engines never try'd the early non dpf 1,6hdi that ford uses until now after a few days of pulling the engine and box and swapping things over it works have it running with no fault codes done dpf delete and and egr delete as well and ecu mapped etc, so it can be done and does work just need some diagnostics gear and map out the dpf and egr etc, even used the injectors from the early engine as well and all encoded easy, car now runs sweet,, really big job ie front off engine gear box out engine firstly stripped to find a lot of of faults from very bad rebuild done in it life proper bodged on many levels, replaced with low mileage ford focus 1.6hdi engine.
