EBC and Track days....BAD BAD BAD
2502 Views 16 Replies 9 Participants Last post by  dukesantos
well i have attached some pics here of EBC Rotors which as you can see where demolished and are heat cracked from EBC yellow/black pads.
Thats 2 track days and 3 sets of Pads.
The Ferodo 2500's have done 2 track days now and are only 1/2 worn.
That says it all... plus the pedal feel is so much better
And here are some new pics of the New DBA542KP Slotteds. These are the new design just released ive been waiting a few months for them.. $140 each through BSMSPORT
1 - 17 of 17 Posts
and some new pics of the New DBA542KP Slotteds. These are the new design just released ive been waiting a few months for them..
Itseems that from all the posts i have read the whole EBC concept dosent work .What pads are you going to run -are you going to try the Ferrado DS2500s-if so would appreciate feedback on how the combination works.:p
I have been running the 2500's for the last month and the last 2 track days... great things... have been using them on the standard discs which are better than the EBC discs...
My personal opinion of EBC is that they are worse than factory! ( but thats only an opinion)
fitting the new discs with new 2500's this week.
That seems to be the general opinion on the sites. look foward to your report! :p
Hmmmm.. If there is one positive out of all of this... It looks like I'm not the only one that's been conned :) :)
Nothing wrong with running EBC's on the road. But yeah most people dont recommend them for track use. They destroy themselves under the heat.
Not entirely true per se. Greenstuff pads are very very good, you just need the correct rotor to pair them with. I have used greenstuff pads on all my cars and have been on track alot with my race-prepped MG ZR. Ironically the EBC rotors are probably the worst out there as many have found, since their grooved and semi-slotted design generates alot of unwanted squealing, does not effectively dissipate heat compared to competitors' models and they have alot of fracture points.
In my experience, you will not get better than the Tar-Ox disks (G88). You can't beat triple heat treating and with the greenstuff pads, its a match made in heaven :D
Plus, with greenstuff pads there is virtually sweet FA brake dust :)
Henry
I have used EBC Green and Red on the street and limited track use, not all out racing. They worked very well on both the Cooper and the S. The Cooper has stock discs, the S has upgraded slotted/drilled discs. I don't think the Greens are better stopping power than stock but as someone already mentioned they sure cut down on the dust.
If anyone has any specific questions for EBC, I will probably stop by their booth at the SEMA show in Las Vegas later this week.
Can you ask them why they destroy the factory disks?? They warped mine (twice) and generally didn't work as well as the factory pads, but they did generate less dust :) I've got a set that are not half worn and I've had to give them up as a bad joke :( Yes that's right, the pads last 40k, but you'll need to fit 5 new discs in that time :(
EDIT: I should add they were greenstuff, and there were no track sessions involved. It was driven as only as hard as the other MINI's and they did't have any problems :(
I bought the Spotties and EBC yellow/black as recomended by EBC themselves.. they are supposed to be capable of a few track days.. for the money spent i was expecting great things. :( :( :( :mad: :mad: :confused:
Then after speaking to some mates who run in GTP production with an EvoVIII they said they went through the saga as well.. in reality the EBC greens are just a low dust pad material. The reds are a little better, and the yellow/black is supposed to be big bertha! But in reality EBC should look at how they bond there materials to there backing plates and maybee Split the pad material in 2 as they always heat crack down the middle creating a weak point. On all occasions running the EBC pad material i have had a chunk of pad material fly out of the caliper. I Beleive that the EBC would be good for a normal car and driver wanting to reduce brake dust or has a show car... but they are certainly not up to task if any performance/endurance is required
Im not bashing the product... as I have sent Photo's and technical data to EBC themselves asking them to explain why it occured when it does not occur with other products.
Greenstuff pads are, relatively speaking, very hard compound pads when compared with OEM fare. Due to the friction compounds used, greater pad temperatures are seen when braking enthusiatically. I have heard of many many people warping stock rotors with greenstuff pads (not just in the MINI arena). Some (like MAX) seem to get on fine with greensuff pads on stock rotors. Maybe they are lucky or drive more responsively where brake use is kept to an absolute minimum. Warpage occurs simply due to the excess heat generated between rotor surface and pad friction compound. On the stock rotors there are no extra airflow measures i.e. slots etc, therefore the disks get really really hot! Cooked rotors means warpage time...
The simple solution is to upgrade the rotors to something more durable; there is a reason why EBC sell uprated rotors you know. They're not intended just for looks :p
A heat treated and very durable aftermarket disk, like the Tar-Ox disks, will NOT warp with the greenstuff pads under normal road and track conditions unless you accidently put the hanbrake on in the pit lane after a 30 lap track outing :p ...
Henry
Something i found amusing was EBC stated that they dont recomend EBC green with there own rotors. they only recomend reds and yellow with there discs. ODD???
Could someone please clarify for me is it the pads or the disks that create so much dust on standard MCS brakes? Must admit it peeves me to no end, just clean the wheels all up and 2 days later they look shocking again.
Jason
Its the pads. Different pad compounds cause different degrees of dust. I expect the stock Mini ones are rather soft and therefore give out lots of crap
Stu
Stu
Can anyone recommend any other brand/type of pad (other than EBC) which will be used for anything other than track work which will not yield the same level of brake dust as the stock pads :confused:
Ferodo 2500's are only a semi track pad... great on the street.. i know others swear by Galfer pads... so theres two to look at
Well I talked to the EBC folks at their booth at the giant SEMA auto show in Las Vegas today. Of course they said that their pads don't eat disks. But they also said that there is a new compound just out for the Yellow pads that has been track tested in the UK.
1 - 17 of 17 Posts
