Hi guys I was wondering if one of youse would be able to help me out, I’ve only had my Mini Cooper 51 plate a couple of months and I love it! Great wee car but unfortunately as of last week I’ve not been able to drive it.
Reason being all of a sudden just the other week there my lights started turning off just randomly, not interior lights as there all fine but the headlights. It all started with my brake lights, they stopped working the week before and I was able to fix it by spraying some wd40 on the pin underneath the brake pedal which resolved this issue. But since then the cars been acting really strangely, if I leave the car for a while and then turn it back on the lights will work... but only if I leave it for a couple of minutes otherwise they will just turn off straight away. Even still, if I leave it for a couple of minutes and turn the lights on after another couple of minutes the lights will turn off again, the sidelights however work completely fine. I’ve also found my indicators occasionally fail and now I’ve got the issue were my brake lights are no longer working again. Checked the fuses and everything seems fine, it’s also worth mentioning my rear lights all work fine also.
Really don’t know what to do, I don’t know whether it could be due to a poor connection or could it be an issue with the earthing?? I just don’t understand how if you leave it for a while they’ll turn on... this however is only the case if you turn the ignition fully off and then start the car again.
To make matters worse, the air con occasionally cuts out but not that of the radio or the interior lights yet again. And the window randomly aggressively goes up and down or stops working both when the engine is running and when the engine is off, even occasionally when the car is turned off. It’s really strange.
Any help would be greatly appreciated guys!
I did have a hunch that it could be as a result of my power steering, I’ve noticed it’s gotten extremely light recently and I don’t know whether this is as a result of an electrical fault or sensor giving the steering pump too much power possibly draining the battery causing issues as the power fluctuations.
