Hi,
How do you identify if you have the higher power engine? Does anyone know which chassis number or engine number they are fitted after.
Many thanks
Milly
Clubman D
The 88bhp upgrade came in from September 2005, but if you have a 55 reg OneD it doesn't mean it is 88bhp, as it could have actually been made earlier say in August.
Easiest way to tell is if there is a big black square plastic cover over the engine, and if the build month is September 2005 or later, check the black sticker under the bonnet above the drivers side wheel arch! :D
thanks i'll have a look
Mine was recently fitted with a new engine.....how can I tell if this is the new engine or the older one?
original car was 2004.....
