My engine light has come on in my 2012 mini one. I took it to my garage who identified a sensor for the crankshaft, replaced that and all was fine and dandy. Then the light came on again. Took it back to the garage. Came up as an historical fault and he took the part off, checked it, sprayed with wd40, put it back on and again, no light. This morning, light came on again. It is now doing my head in! Any suggestions? The car was a bit stutter this morning until the engine warmed up? Update... When I left work, the light was on until I neared home and it went off. It didn't come on this morning. Went out at lunchtime. Light came on when I returned to office. Any ideas
Buy a Creator C110+ code reader for BMW/Mini. You can probably also check codes using the Check Info function using your left hand steering wheel stalk button thingy. The car user manual tells you how to do this.
