Addicted to Speed!!
Did anyone get to the bottom of the engine rattle on startup from cold? Is it the hydraulic tappet adjusters starving from oil when the engine is left overnight?
Mine did it again today.
Addicted to Speed!!
Discussion Starter · #2 ·
Talk about coincidence!! I have just this minute returned from my local paper shop in my MINI to see another MINI parked there the same spec as mine! (Bugger. I thought I was the only one around here!!)The owner saw me outside and after the usual "what do you think?" he said,
"Just one thing. Does your engine rattle like hell from cold?"
:confused:
Mine's been doing it to.
Not nice to have a sporty little car that sounds like an oil burner when started.
Jon
P.S. Saw 3 the same spec as mine on Sat - bugger!
Have any of you done an oil change yet? The rattle may be due to the oil filter. Most filters have a drain-back valve to prevent oil from leaking out so when the car is started, the oil pressure comes up quickly. If the filter either does not have the valving (some cheap ones don't, some are smaller with less oil capacity and who knows what they use at the factory) or the valve is stuck open, it can cause rattle on startup. Be sure to insist on a top quality filter when the oil change is done and see if the rattle goes away.
Rattle
Mine rattles too.
I'm calling the dealer tomorrow.
Hope it's just oil & filter change.
Problem with the MINI is, I'm led to beleive it's not your normal spin on filter, it's a special MINI cartrige filter.
