big problem with reduced pulley is need to have a good tight belt to fit it then we found with a cam and at point of where the cam picks up found was getting some slip so end up putting a smaller belt on by undoing the alternator to get belt on as was not enough travel in tensioner for pulley ,, i think would be better if made a tensioner that can be adjusted via crew threads and not sprung tensioner as such then could avoid belt slip,, the less the bottom pulley must turn it always going to better also using a good new belt helps things,
