1 - 20 of 25 Posts
Hi Eveyone,
Despite having a new fuel pump and some other parts (which helped it run smoother on power) my R56 with N14 engine still has a rough idle. That is not to say I get rev fluctuations, only that the engine vibrates more than I think it should giving slight hickups here and there. Better when warm but never 100% gone. It bugs me!
After reading about Vanos problems and finding a description that matches my symptoms I changed the Vanos solenoid to no effect. Now I want to check engine timing / chain.
Today I put the cams in upright position (TDC, or it could be crank at 180°) and placed a ruler on each of the the square sections where the locking tool usually goes. I took a photo with camera on a static tripod so I can compare intake and exhaust angles. I seem to have about 2.9° difference. See photo. I'm unsure if this is advance or retard?
Anyway, I wanted to confirm that this is not normal, is it? The resting position should have both cams with the square sections exactly aligned, correct?
Just counted the Vanos gear to have 40 teeth, so 9°/tooth. It's not slipped a tooth. Simply a worn chain or lack of tension?
I also checked the Vanos seals that feed oil from cam to Vanos. I read they are rubber on some BMWs and can wear out but mine seem to be steel.
Also I put a spanner on the intake cam and found I was able to move it slightly against the spring of the Vanos gear. It wasn't 'easy' but it was possible with one hand. Video below. Is this normal? I read somewhere it should not be possible to rotate the cam... but the Vanos is a sprung gear.
Insight appreciated!
Vanos cam spring:
https://youtu.be/WojmAbBXi78
you can rotate the vanos with some force agaisnt a spring that thats it back to its start position every time, on start up both vanos will get loaded with oil pressure controlled by the valves and have a on idle slightly moved off the stops and as engine revs harder they rotate more,
2.6degrees on top sprockets will be a lot on the longer parts of chain to bottom sprocket, you need a locking kit and lock engine off correctly.. or if were me and car has done 60k plus on that chain kit just repalce it before it lets go and turns a £300-£800 depending on who doe it job into a 3k for new engine job, look at the chain tensioner how much of the end of the plunger can be seen measure it, a new chain kit will be around 5mm worn out 10mm-14mm
Thanks Mike. The car is only on 49K so it does seem early for a new chain but regardless it's an 07 plate so not a young lad anymore.
How can I check the tensioner length, please? I don't think I can see it from with the valve cover off. Do I just remove it, or then it will spring to full extension?
below link is best way i can help you with out spending the afternoon typing
https://hausofminis.com/2015/05/is-...ing-chain-on-your-2nd-generation-mini-cooper/
as for 49000 miles i have seen them gone at 24000 miles before on turbo cars, my theory behind this is, when car new new owner dont know that those engines use oil by design low friction tech so they run them under the full mark and thats the big issue,, that engine you must treat the max fill mark as the min level never want ot to get much under it, as when do the chain dont get enough oil to it, the cams might not get enough oil to them so causes drag on the chain, also the oil gets very dirty on 20k service times then add to this someone runs the oil low even less oil to keep clean and can over heat the oil this breaks down sooner and wear just gets worse,
turbo cars dont tend to get much past 70k on chain when they are looked after and driven at lowish revs.. bmw mini decided the fix was to produce a tensioner that is twice the length as the standard ones as a fix, but that just moves when the rattle begins and not when the out of timing engine starts eating its self from heat etc, the real fix should of been a duplex twin chain system like bmw used back in the 1990s on 2.5 tds engines
I had a quote from my favourite garage of £660 inc. VAT for a timing chain replace. Ouch! I thought it would be about a 3 hour job for a practised garage. I guess I'll do the job myself. Are there any unexpected 'gotchas' I need to prepare for?
will need a special locking tool with chain dummy tenioner 27mm thin spanner the cheap ebay locking kits are hit and miss i have a couple and when compared to a £200 draper one can be 2 to 6 degrees off time, £660 is fair price i no Peugeot main agents on same engine £850 ish,, one ideal would be buy a good one then rent it out take a online deposit off people before postage maybe might even make a few quid off it.
Whats' the dummy tensioner for?
27mm thin spanner for the aux belt tensioner?
i did refrain from any joke reply lol,,
so you remove old chain kit and then slide new one in with bottom sprocket held by the chain and guides clipped together and put all the guide pins in and vanos sprocket on loose and the bottom sprocket loose, so all sprocket can free turn on their shafts,, at this point you use a dummy tensioner,, ie its same as spring one but has a threaded bar to manually set the amount of pretension force on to the chain tension guide,, ie just enough that it dont flex the guides in any way , at that point can set sprockets to 20nm torque wrench,, then remove locks and turn engine by hand 4 times over then relock and check if all locks drop on to the cams after setting the crankshaft pin,, if does i always insert the spring tensioner and repeat this for peice of mind,, if dont match up then either to much force was on the dump tension tool or not enough,, ie its trying to match the load of the sprung loaded tension with the manual one when setting it,,
i know this all sound alien complex but its just a process, the first time i ever done one i got it wrong but caught before running the engine or doing up the stretch bolts etc,, check re check it this dont cost you a penny just 10 minutes of time,, ie must be able to lock crank shaft then just drop the cam locks in to place when checking timing always final check before doing stretch bolts up is try with spring tensioner in place,,
Discussion Starter · #9 ·
I haven't retimed the engine yet but I was having trouble finding the cam stretch bolts without buying the Vanos gear and sprocket too. However I just found them by using the part numbers from RealOEM. So in case anyone else needs it the intake Vanos strech bolt is 11367536087 and the exhaust sprocket strech bolt is 11367545863.
ocean bmw plymouth sell them over counter £2.90 ish
  • Like
Reactions: ssashton
Discussion Starter · #11 ·
Okay time to give an update on this.
I re-timed the engine over the bank holiday weekend.
I used a cheap timing kit from eBay. Yes, I had to reduce the main body of the crank pin to fit the flywheel housing bore. I just stuck it in a drill and used a small file to work it down.
Also yes, the timing lock fixtures needed a little work. The exhaust lock needed a small section cut off because it interfered with the turbo (I think an extra screw hole for mating with another engine) the angle-grinder took swift care of that. AND yes, the locking fixtures needed some shimming to get a really snug tolerance fit on the cams. In my case the exhaust fixture needed 0.14mm shim and the intake needed 0.1mm shim.
Once I put the crank pin in, the exhaust locking fixture slotted dead-nuts on. Nice. The intake fixture on the other hand would not even go on more than half way because the intake cam was angled backwards towards the engine bay bulkhead. So yeah, it was out of time. I don't think it is chain wear because that would be spread across the chain evenly and appear on the exhaust and intake cams. In this case it was only the intake cam and I think it was probably not installed carefully since I found the valve springs wanted to push it off time just like I found it here.
I removed the timing chain tensioner and replaced with the manual tool done finger tight. I'm not really sure why I shouldn't just leave the automatic tensioner in there (except if you are replacing the chain).
In order to loosen off the vanos intake sprocket bolt I needed to remove the top brace / radiator mount and also remove the intercooler to intake manifold pipe. Using a swivel socket to avoid the engine mount I was then able to release the stretch bolt and adjust the intake cam relative to the sprocket / timing chain.
I installed the new stretch bolt (20nm) and did a few test rotations, then reinstalled the timing tool. Then I did it again to be sure before I torqued the bolt 180 degrees for final tightness and did a final third test rotation and locking kit install. Everything was perfect!
Oh, I will warn you that the tensioner hole is fed with oil. So I got a nice pool down the back of the engine when I did my test rotations with only the manual tesnioner tool in there.
The result? Well at first it seemed to run smoother. Then it didn't, then it did. I think this has helped, I mean it can't not help getting the engine timed right. However first I think I will need to have the adaptions all cleared so the ECU can learn the new timing. Second I have a suspicion I need to check the sensors and wiring. Yesterday I gave my MAP sensor a blast of alcohol to clean it and now the car actually runs worse than before, so I suspect a poor MAP sensor or weak wiring too. I battle onwards!
the joys of them, as chain was out very clearly after getting timing back right it will either need a few hot to cold runs to get ecu to reset its self, after this if still doing it then finding whats been taken out more than likely by it be out of time. ie the cat or and upstream 02 sensor could even be a ecu issue for the 02 sensor as on psa cars have seen the 02 sensors get so hot they melt and dead short back to ecu, all maybe's,
Discussion Starter · #16 · (Edited)
I still haven't had the Vanos system and adaptions reset as I started to get fault code '2B64 - Intake manifold, unmetered air' and I wanted to check the MAP sensor and wiring first.
I finally got around to it today and have a new MAP sensor as well as checking wires and putting new connectors on the plug. Still the exact same situation.
SO - is it possible the 2B64 fault code is simply caused by me changing the engine timing and not resetting adaptions yet?
I have of course checked for vacuum leaks and can't find any.
at 49000 miles that engine is well on its way to needing a chain kit just to get that out there and i would not do what you have done with retiming up a stretched chain as tensioner will be on its last legs, that fault code is a breather or pcv leak somewhere, maybe the rocker cover is leaking or the solid plastic breather pipe has split or the connections are leaking somewhere, the best way to find these leaks is smoke test, i have a cheap £20 disco smoke machine and add ultra violet in to the solution and change the inlet with it see where it leaks.
for adaptation reset could do a hard reset as per below
How to reset all ecu's
this procedure is called a power latch
firstly turn on the ignition not engine running,
open bonnet remove battery positive lead and then turn off ignition.
then touch the positive lead to earth,this powers down all ecus and resets erasing intermittent faults in the process.then reconnect the battery lead.
if the vehicle doesnt start straight away leave the ignition on for 2-3 mins as it has gone into anti scanning mode.
IMPORTANT PLEASE READ CAREFULLY
upon starting the vehicle DO NOT TOUCH THE THROTTLE allow vehicle to idle until cooling fans cut in to allow the engine ecu to reset correctly and reprogramme the learning curve,then drive in all gears upto 4,000 rpm accellerating steadily.
as stated this resets all ecus so any electrical faults caused by conflict errors in programming will be erased and fixed.if the fault is still evident there is a problem that will need further diagnosis
I don’t get this, when the positive is disconnected on a gen2 I cannot turn the ignition off as the key is locked and start stop button is deactivated? Any hints please?
push the start stop button so has no lights on dash and disconnect the battery and go through the process
1 - 20 of 25 Posts
