you put fob into dash press start button as to turn on ignition ie all fuel gauge comes to life etc,, at this point the ignition is definitely on, then press the button once ie this switches off the ignition leave fob in dash then disconnect battery and cross them,, thats the beginning of it thought that would be fairly straight forward to work out on a car with a start button and not a key you turn, the fact the button does away with the rotary movement of a key but still does the same thing,
