hi, i have an 2007 mini cooper s. i have the error code 28AA (divert air solenoid valve plausibility). This is usually cured by having a new blow off valve which i have recently changed and made it slightly better. This problem occurs when the car is hot. i can drive to work and hit no traffic and the engine light will not come on once. I presume this is as the car is getting a constant air flow. if i hit traffic and the car has been sitting for a few minutes the light will come on near enough straight away when hitting boost. can anyone help as i’ve checked and tried everything and a bit stuck where to go from here, thank you in advance
