SCNM Oldie!
Hi everyone a quick question i need to know the internal and if posible external diameter of a UK spec R56 Cooper s, exhaust pipe that is running under the car. Because i want to get the silencer/resenator removed from under the car for a better exhaust note, and i will be needing to weld a new piece of pipe in place of the silencer so i need to get the same size pipe. All help will be great.
JCW 250
Not entirely sure but I think the clamping bush is 55mm diameter - so that may be the external diameter...
Measure the circumference then you can work out the external diameter -> the diamter = the circumference / pi.
pi = 3.14 to 2d.p.
Other than that Im affraid I cant help... :)
