F56 diesel
127 Views 1 Reply 2 Participants Last post by  Rockster
My f56 diesel stalled this morning and will now not start. Turning over OK but not firing. No fault codes present.
Got fuel?
Do you hear the low pressure fuel pump running? You may need a helper to attempt to start the engine while you are near enough to the the low pressure fuel pump to hear it running.
Of course if it is not running then any fuse and relay in the circuit need to be checked.
With a gasoline engine when one of my cars failed to start and the fuel pump was not heard I checked the fuse and relay. Both were good. Got the car flat bedded to a dealer. Tech cut right to the chase. He accessed the fuel pump disconnected it from the wiring harness connected 12V shop power to the fuel pump. It did not run. A new pump was installed and that was that.
