Hi,
Does anyone know where the mic is fitted on the facelift if you opt for the optional bluetooth?
I have asked my dealer and they have no idea!
I know the earlier one had a bit on the clock thing where the mic went, but I fail to see where its suppost to go on mine.
I was wondering the very same thing as I drove to work this morning!. Sorry I can't help, but I can add my pending thanks to anyone who shares the answer.
Well considering even the parts manager at mini didn't have a clue, I'm not sure there is much hope!
He did say if I wanted bluetooth fitted they could do it for just under £2k :confused:
It depends on your model.
Hatchback without sunroof, you get a seperate little moulding in the roof liner.
Item no. 10 here :- RealOEM.COM   BMW R53 Cooper S HEADLINING / HANDLE
Hatchback with sunroof, it fits into the sunroof control panel in the headliner.
Item no. 10 here :- RealOEM.COM   BMW R53 Cooper S HEADLIN./HANDLE LIFT-UP&SLIDE-BACK SUNR.
Cabrio, it fits into the header rail trim near the folding roof controls.
Item no. 4 here :- RealOEM.COM   BMW R52 Cooper S TRIM PANEL A-COLUMN/INT.WINDSHIELD PANEL
Hope this helps.
Where does item 10 fit though?
Does it basically require a different headlining, or am I missing something?
Regards,
Hollinshead.
Discussion Starter #7
So basically you have to hack the headlining apart?
That mic holder looks massive too!
I think I'll look for an alternative method, like hiding it round the back of that airbag light or something.
I don't suppose anyone has a pic of this fitted to a ph2 r53 do they?
THE STICK
They are very directional, so hiding it is not a great one I'm afraid. Really it needs to be in front and above you as much as possible on all the kits I have every had or seen. They tend to lose the pic-up very easily if they are aligned either directly above or facing the wrong way. The MINI one may be different though
