HI Guys,
I have a 2010 Camden and its been a naughty boy recently ! It started with burning a little oil, 500ml every 3 months. No visible leaks, no smoke.
Then we ran very low on oil for a few weeks and when i wen tto top up, I did a full oil change and filter at the same time. Still no visible leaks, but since then some blue smoke and higher consumption. It culminated in awful rough running and spark plugs soaked in oil which wasn't great ! Valve cover off, and the seal was perished, all hard and crap. Got the seal kit, cleaned up the plug wells, and changed the plugs. Good compression all round and after that it worked larvellllyyy for 3 months. That take us to now and he just failed the MOT on smoking and had low oil going in apparently (this was BS, i topped him up before i went but i went along with it as it was free to top up).
I think it may be valve stem seals, all makes sense but when I took off the valve cover to get started, I noticed the pictures. The seal was in there but would it be doing anything with the cover broken like that? If I dive in and do the seals, should I change that valve cover , so bite the bullet and just get one, and also a new PCV in the process. Or ..... do i get the valve cover only, get it on and see if it improves, saving muchos effort and cost ??
Whilst in the top of the engine, is it better to directly apply some sort of snake oil, rejuvinator to the valve stem seals ?
Running loads of oil through my exhaust will no doubt have filled it with crap ? Is seafoam or Cataclean a good shout for a clear out ?
Thanks in advance , sorry for long post !
P.P.S happy with my new phone camera too !
