Hi all,
I'm the happy new owner of an '04 Mini Cooper, with factory navigation. It seems to work fine , although it's in need of an OS update, and a newer map disk. There is one thing that concerns me: the nav screen has a noticible (sometimes very noticible) flicker.
Any idea what is causing this, and how to fix it? :puzzled: I searched before posting, and didn't find anything.
Thanks in advance!
Susan
MMC Member
This is not normal at all. It sounds like a loose connection of some sort. Hate to say this, but a trip to the dealer or an audio video specialist is probably required.
There are 3 connectors between the NAV computer under the seat and the display in the dash.
1. @ the navigation computer on the back of it under the seat.
2. near the fusebox in the LHS footwell
3. @ the back of the display in the dash
suggest you check these 1st.
r u running on stock power cables or have u swapped them for performance ones? ie Nology power cables. Reason being, a friend of mine had the same problem and found that it was the culprit.
Thanks for your replies! I'll definitely check the connections before going to the dealer. The wiring is the original from the factory.
Again, I appreciate the advice, thanks for your help! :red:
