It is easy to replace the FRM with an used one only by taking the following steps:
1) You must replace the FRM with one of the same or higher model (check which FRM model corresponds to your VIN).
2) The FRM saves the VO backup that is stored in the CAS. If you simply connect the used FRM, you have not the correct VO backup (which may differ greatly in active / non-active functions). You must change the VO list in the FRM to be identical to the one stored in the CAS.
3) You must change the FRM VIN (overwrite it with your MINI VIN)
4) After performing the 3 steps above, you must re-program the FRM to it default state (it will be auto-configured according to the current vehicle's VO).
If the FRM is in good condition, after these steps, the FRM will run as the OEM
