how are you supposed to get at/remove/inspect the bulbs in the front fog lamps? from the top? from underneath? MiniGuy? :)
It says in the manual that you should consult the dealer if a fog light fails. I don't use the fog lights much but am not very happy if I can't change a bulb in the car myself.
If someone has done it, a "how to" article in the FAQ section would be excellent.
KenL
Remove the bulbs from the bottom sometimes easier to take the front wheel off gives you a little bit more room definitely underneath changed mine on my r57 Mini Cooper 2012.
Second generation mini is easy. Take off the dusty cover and turn 45 degrees Counterclockwise of the lamps.
However, for long time used car. It may sticked and hard to remove. Than, it’s better to take off front wheel and use kind of tools to take it out.
Sent from my iPad using Tapatalk
