81 - 100 of 124 Posts
ok so took the clip connection off the passenger-side float sender unit, under the back seat. These are the pics showing.
Now unplug the connector off the fuel pump/sender and do fuel levels again, that will determine which side it is.
Lift out the RHS (drivers side) unit, that houses the fuel filter, and check the black and green wires that connect to the other unit. They are very fiddly to lift out, just keep tilting and turning it slightly. Be careful of bending or damaging the float, it can be lifted up enough to check the wires.
I will do that now.
come back to you soon.
Wires all ok and connected.
So the pump wasn't the problem, I feel there has got to be a break in a wire. The pump is the passenger side and the filter the drivers side???? Is that correct?
Did you check the two earth/negative wires in the rear passenger footwell?. The two wires connect to one black negative wire (they sometimes corrode). Pull the carpet down and remove the plastic sleeving on the wires to see if they have corroded/rusted.
All the wiring seems ok..
Do you think it might be the cable under the black tape that’s dodgy?
Yes the pump is drivers side. It does have a float on it to. The passenger side is the sender unit. It has 2 floats on it.
Would you no if there is wiring under the car? Or is everything confined inside?
Take the inner sill plastic trim off and peel the carpet down, passenger side rear footwell. This will give you access to the wiring loom. Unravel the tape and you will see all the colour coordinated wires, you are looking for two black wires that connect to one black wire (shrouded by a transparent plastic coating) . Check these connections have not coroded/rusted away. The two sender units and the fuel gauge will be fine, it's what connects all three together....the wiring!.
Is it this one? Seems ok.
Think I found it...
Took the black tape off the wires from the sender (in pic) and found it was broke and wet. Going to fix it and try it.
will come back to you on the update.
It’s FIXED!!!!
TexM, you were right with the earth under the tape in the last pic! Can’t believe I never thought of taken that off the last time.
Thank you again for all your help and hopefully this will help someone else down the line.
message me if anyone is stuck and I’ll try and help, like it was given to me.
I'm happy it's working for you. It took me 3 days to fix the wife's mini, very annoying if things don't work as they should.
What's a " cockwomble " ?
TexM - I have been following your solution which sounds likely to be my issue. Can I ask - on menu 6.2, were you getting error 2 - Sender Failure?
I am getting error 2 which I think tells me that the gauge can communicate with the pump (therefor not the wiring between pump and gauge). I have replaced the pump and still have a dead gauge, so I was thinking it must be the communication between the Fuel Filter side and the pump (or a broken sender at the Filter side).
I had read somewhere never to take the filter unit completely out. Did you manage to get it fully out for the repair?
Thanks in advance!
