1 - 1 of 1 Posts
2003 R53 Cooper S
Hi all
I have just completed a set of mods
18% smaller pulley
BMWI/250/400 PH2 Cam
IC
550CC injectors
All tuned for the above mods, reset all adaptions and throttle body stops etc.
I fixed a few small intake leaks (Green boot on the inlet pipe after the throttle body, and one of the o rings to the hard line.
The car runs well, has great power, however, my fuel trims at idle are -13 to -15% in closed loop. When driving along at constant throttle in the midrange they are closer to -8%.
Do I need to sanity check my tune? I would expect that the scaled injectors in the map would work for both closed and open loop.
I also have a random lumpy idle, not quite a misfire but getting there. It goes away if you blip the throttle. Cam related or requires further investigation?
1 - 1 of 1 Posts
