1 - 12 of 12 Posts
Hi folks, this is probably an easy fix, but my glovebox light is not working.
It never worked when i got the car last week, I have changed my interior lights to led's inc glovebox lights and still not working.
Any ideas how to fix ?
all other interior lights work not sure if it would be fuse unless this is on a different one to rest of interior ?
anyone else any suggestions?
What year is the car John? It may not have had a glove box originally and then had one retro fitted but not wired in! I retro fitted one in for my mate last year but I wired his up so it works when it opens
Could be a break anywhere so you'll need to check from the switch back. Get yourself a test lamp or multimeter as this will help trace the fault
Hi Sean, I have just retro fitted a glove box to my 02 Cooper (R50) as it only had the shelf, can you remember where you picked a feed from for the glove box light?
Regards, Brian.
Hi Brian, you can easily pick a feed off the cigarette lighter as that's fed off the ignition and saves splicing wires if you use a double spade terminal ;)
I have a F55/F56 car without a light package, but it have a glovebox connector an on/off switch. I suppose that previous car's owner can install a light lamp into the glovebox, but the cars without a light package does not have a 9pin Red/yello wire in X434*1B connector that connects a glovebox light to Terminal 30B (Fuse F70 and relay) to provide a power for glovebox lamp. You can cut a red/yellow wire on the pin9 X434*1B connector and connect it directly to the red/yellow wire from the Z4 front power distribution fuse box.
1 - 12 of 12 Posts
