CHEQUE IT OUT
ive currently got a blue flame exhaust, with two ovals on each end not the middle(the one from minisport)
i was thinking of going back to standard, as i am now commuting to work and its so annoying on the motorway, sounds ace on normal roads but too loud and manotonous on motorways.
i am running a 15% pulley plugs and pipercross induction, will i notice a difference in performance.
the website claims 10-15 bhp increase. dont want to swap if it will feel a lot slower:angry:
http://www.minisport.com/newmini/acatalog/info_NMPEXH100.html
cheers
a.k.a. BrainRush
I also have a 15% pulley and an induction kit, but do you really think that roughly 10% of your car's power will be lost by adding a few extra bends in the exhaust?
The biggest difference I think you'll maybe notice is difference in weight, which will net you 10 or so pounds, and since each 10 pounds added to a car is equivelant to taking away 1 hp, I don't think you'll notice much difference. unlike the days of yore, modern cars arre designed to be more fuel efficient, as opposed to cost efficient to produce. So where as a car in the 60's or 70's would have a cast iron exhaust manifold log leading to a muffler with more kinds and baffles than you could car about, modern cars are more and more often equiped with a tubular exhaust manifold and into a better researched exhaust system. my 83 mercedes 500sl averaged 10-ish MPG, now cars similarly engined cars are doubling that.
in short, if you have the stock rear bumper, and are sick of the sound, I'd go for it.
MINI2 Rebirth
Yeah, I doubt you'll really notice much of a difference in power if you go back to standard. Changing the cat-back exhaust makes much less of a difference (and that's even with best in class products like Milltek) than changing the manifold.
Take off the fancy exhaust and flog it :)
THE STICK
I doubt you'll notice a difference. Why not go to stock and then put a GTT reroute 'one ball' pipe on to reduce restrictions and weight on the stock system. I think that GTT do this section for about £60-70 and I know that places such as ThinkMINI can fit them.... or in fact a decent local custom exhaust place could do it. Will give you a little more burble than stock without loosing you power.
TBH I know someone who had a blueflams and he didn't rate it for the power on the S
