The electrics I’m not sure about, but it sounds like the car went into limp mode as you drove it back...my hunch is head gasket, as it sounds like a leak has sprung, causing the misfire and sludge in coolant tank (most probably oil).
Get the cylinders compression checked and, if you can, scan for codes...
