Hello everyone,
I am Quentin, 30 y.o. proud owner of a Mini Clubman 1.6i 2008MY.
I have this car for a year now and despite an ABS/DSC issue, I am very happy of its quality, its drive and its fuel economy. I manage to have an average of 35MPG (70% city driving, the rest on country roads and highways).
I purchased the car with a triangle lights on thinking it would be a simple wheel sensor change.
I changed them all together with the brake pad wear sensors.
I also changed the brake rotors and pads, front wheel bearings, change the engine oil, transmission fluid. Working on this car for usual maintenance is quite simple and straight forward.
Regarding the ABS lights, I have these 3 following codes: brake pad wear sensors: 5DB2 5DB3 5DB4.
I changed the yaw speed sensor under the front seat (previously cleared the fault, disconnected the battery), drove it 50miles and didn't see any positive outcomes.
Do you reckon it could come from a faulty ABS module? I am also thinking of a broken cable or a bad connection, I haven't done any continuity testing so far but I haven't seen anything wrong by eye. I cleaned the conenction and use eletronic cleaner all around, left the connections to dry before plugging them back together but still the light turned back on.
