Newbie here, from sunny Qatar, with a broken down 2006 R53 JCW 6 speed.
Having problems with fuel supply - it completely ran out of fuel (faulty gauge showing quarter of a tank) and now refuses to start - even after a new fuel filter, and replacement (used working oem) fuel pump, just to be sure. All obvious things like fuses, relays, grounds and connectors checked. It cranks over well enough, there is spark at the plugs, just no sign or smells of any fuel whatsoever. Pump is priming and pumping when it cranks over, but not getting to the engine.
A local specialist garage couldn't extract any OBD2 codes using all 4 of their code readers. But I have just managed to interrogate the on-board diagnostics, and retrieved 2 codes from the display on the dashboard, as follows:
102101 and 112101.
Does anybody have the listing to work out what these on-board diagnostic codes mean ??
Well there's more than our fare share of exotic cars here for sure, but being an expat from old blighty, its nice to be different ! I have yet to see another R53 JCW out here.
The garage reckon the fuel injectors are ok, "from what they could see". :unsure:
But doesn't the way it broke down, suggest it is a fuel supply related problem ?
