dear all
just picked up my mini cooper convertible. 2 questions
the pdc is very loud compared to my previos mini cooper ( the book says you can adjust it but it does not say how ) can anybody let me know how to reduce the volume of the beep.
also,
my last mini cooper front lights stayed on for 20 seconds after ignition turn of but this one does not stay on ( why ) and can i adjust thsi myself.
thanks, i wait to learn from you
Can hopefully help with the 'follow me home' lights.
Switch everything off, lights inc. and take key out of ignition. Pull light 'switch' towards you (like flashing your lights). Headlights should come on for you. Mine go off after about 30 secs - I think the actual length of time they stay on can be set by the dealer.
Hope that helps!
· MINI2 Newbie
Oh goodie, I think I can help you with both questions! About the PDC, the dealer can lower the volume for you as it is a car memory feature. (You CANNOT do it yourself, sorry.) Also, like that guy ^^^^^^ just said, if you pull the signal light toward you after you have turned everything off, the lights will come on for 40 seconds (or longer if you ask the dealer while you are setting your PDC.) Also, while you are at the dealer, ask them about all of the other options that you can set... :D Hope I helped.
Hunter
